3D graph color ramp (color spectrum)
Dear all:
              I have a question. I use 3D surface funtion in LabVIEW 2011 to draw and want to export the image. However the image dosen't have color spetrum (color
image). How do I solve the program? Thanks.
C.H.
(2,953 Views)
Hi chw0105,
Hope,reading these threads will help you to solve your issue:
http://forums.ni.com/t5/LabVIEW/3D-Plot-Color-Ramp-Colors-to-Values/td-p/1823745
http://208.74.204.114/t5/LabVIEW-Idea-Exchange/The-value-range-for-3D-graph-color-ramps-should-be-co...
Thanks as kudos only:)
(2,928 Views)
Hi chw0105,
You can use the "Get Image" invoke node. Here is an example of exporting the image to the Picture control. You can also save it to an image file, such as bmp or jpeg.
(2,925 Views)
