3D graph color problem
I have tryed to change the color of the frame (border) of 3D Surface plot
its
changed (I saved) but when I reload this vi to the memory its goes back to
grey
color which is standard. Could u give me advice what I have to do in this
case???
PS.
The same problem under windows also...
(2,862 Views)
evgzor,
What version of LabVIEW are you running?  I tried this on my computer and did not experience the same thing.  My frame color stayed the same.  How are you changing the frame color?  Did you Right Click and select 3-D Plot Properties?
You could also set the color programmatically, using the Frame Color property detailed here: http://zone.ni.com/reference/en-XX/help/371361G-01/lvprop/3dgraph_graph_gridplane_framecolor/
Drew T.
Camber Ridge, LLC.
(2,845 Views)
(2,839 Views)
