3D curve plot
In 3Dcurve plot when the size of points is big enough and the position of the curve is such that some of the points are superimposed how to make difference which point is in front and which back. Are there same way to make a visible contour on the point or shadow/light to apreciate the position?
(2,948 Views)
I found no way of setting the shadding option on 3D plot.
Zvezdana S.
(2,948 Views)
Hi Zvezdana,
Dobro utro
I was playing with lighting and that can approach considerably, but I think the best way to show which point is in front/back by making a contour available with different color. That will help understand complex plots.
that should be also a recomendation to NI team
blagodarim
(2,948 Views)
