3D bar graph
Hello, I'm working with a 3D bar graph I've connected a matrix on 3D Bar Datatype.lvclass:PlotHelper.vi. I've some problems with this graph: - aparently, each row of my matrix is considered as a data: with a 10x7 matrix, my graph has 10 different colors (one color by data/row). If possible, I've would like modify the color of each bar independently depending on the value. In a first step I've setted all the bars at the same color withe the property node "color and name" - if possible, I want to activate a cursor, or something else to have the Z value of the seleted bar (with mouse). I've tested all the proerties but it doest't run... - is it possible to write the Z value on the top of each bar? Thanks for your help and examples
Francis M
(3,373 Views)
Hello Cisco,
It is not possible to write the Z value on the top of the each bar. It doesn't exist a node propertie to select a bar in the 3D bar.
I hope i answer to your question.
Romain P.
National Instruments France
(3,332 Views)
Thanks for the answer.
My cursor now properly runs. I've justed displayed the cursor point, and noticed it's possible to display cursor name and coordonnates --> I can see the "Z" value on my graph.
But is it possible to change each bar color, depending to the value?
Francis M
(3,322 Views)
