3D Picture - Shadow Mapping
There's a way to create a shadow (or atleast one workaround) using the 3D picture?
(4,604 Views)
Nobody? I'm able to apply the shadow map with C/LUA using the stencil buffer, but seems the required property isn't exposed by LabVIEW Smiley Sad
(4,511 Views)
I, for one, have no idea what you are trying to do.  Can you provide two pictures, a "starting Picture without Shadow Map" and a second picture after the Shadow Map has been applied?  It might also be helpful to have some idea of the code you are using to produce the initial (non-shadowed) picture.
(4,499 Views)
Oh sorry,  take this as an example:
[1] - Light Source
[2] - Diffuse and Specular Material Components
[3] - Shadow Projection on the plane (a.k.a Shadow Mapping)
I want achieve this effect on my simple solar system using LabVIEW. As you can see, the moon isn't covered by the earth shadow.
(4,481 Views)
If you search the Web for LabVIEW Ray Tracing, you can find an IEEE paper discussing this topic.  I don't currently have access to this paper, so I don't know if it would be helpful ...
(4,460 Views)
No this is not possible.  A LOT of 3D functionality is not exposed int he picture control including multiple texturing, bump mapping and so.
There's a bunch of files somewhere which provided a full OpenGl interface but I don't recall where I saw it.
Maybe searching for full openGL LabVIEW might help.
(4,443 Views)
@Intaris
I've searched for something like this, but without success. Anyway, i hope NI someday improve the 3D picture exposing more OpenGL functionality (i'm not asking for *very advanced* things like tesselation, but, at least, the basic things like shadow, reflection and multexturing) or porting some widely used scenegraph library like OSG.
(4,397 Views)
