[3D Picture] I'm missing something...
Why the following piece of code don't produce the same result in Scene Window (Text position is fixed when i'm rotating the object) and 3D Picture Control (Text position is changing...) ? Aren't they supposed to do the same thing?
(3,371 Views)
Accepted by topic author uChiron
Looks like you need to adjust the camera settings for the 3D Picture indicator to match the default of the Scene Window popup. So the 3D pictures are both the same, it's just the camera perspective difference.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(3,352 Views)
Thank you. Now it works
(3,340 Views)
