3D Picture Control not working correctly
I am currently having problems using the 3D picture control on my laptop. When I place the 3D picture control on the front panel it appears transparent (i.e. no black background) and when I try to load a object into the scene it doesnt work. I have used the 3D picture control on other computers before and have never had such a problem.
Does anyone have any ideas what wrong? I updated my graphics device to see if it was that but had no luck.
Please find my computer details below.
Jack
Product Detected      Mobile Intel® 945 Express Chipset Family
Current Driver Installed     7.14.10.1504
    Intel(R) Graphics Media Accelerator Driver for Mobile Report
Report Date:        04/27/2009
Report Time[hr:mm:ss]:    13:29:16
Driver Version:        7.14.10.1504
Operating System:        Windows Vista (TM) Home Premium* , Service Pack 1 (6.0.6001)
Default Language:        English
DirectX* Version:        10.0
Physical Memory:        2037 MB
Minimum Graphics Memory:    8 MB
Maximum Graphics Memory:    256 MB
Graphics Memory in Use:    88 MB
Processor:        x86 family 6 Model 15 Stepping 2
Processor Speed:        1662 MHZ
Vendor ID:        8086
Device ID:        27A2
Device Revision:        03
*   Accelerator Information   *
Accelerator in Use:        Mobile Intel(R) 945 Express Chipset Family
Video BIOS:        1377
Current Graphics Mode:    1280 by 800 True Color (60 Hz)
*   Devices Connected to the Graphics Accelerator   *
Active Notebook Displays: 1
*   Notebook   *
Monitor Name:        Generic PnP Monitor
Display Type:        Digital
Gamma Value:        2.20
DDC2 Protocol:        Supported
Maximum Image Size:    Horizontal: Not Available
            Vertical:   Not Available
Monitor Supported Modes:
1280 by 800 (60 Hz)
Display Power Management Support:
    Standby Mode:    Not Supported
    Suspend Mode:    Not Supported
    Active Off Mode: Not Supported
* Other names and brands are the property of their respective owners.
Message 1 of 10
(4,785 Views)
For what it's worth, I had a similar problem.
Order of Transformations example doesn't work
Speculation was that the Intel Graphics driver wasn't up to the task.
I haven't followed up - it was a matter of curiousity, not need, in my case.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 2 of 10
(4,770 Views)
Hi Jack,
Steve makes a good point, are you able to check that the driver sets you have currently installed are the latest ones?
Steve H
Message 3 of 10
(4,710 Views)
Hi guys,
I have checked and the current driver I have installed is the latest one available from Intel. So I'm guessing I'm simply stuck? Does anyone have a list of graphics devices (preferably on board graphics used in laptops) available that will definetly enable the 3D picture control to work?
The reason I ask is I have used the 3D picture control on my major project this year in my degree and have to demonstrate the outcomes in two weeks and the only laptop I have been able to get the 3D picture control to work on at the moment only has 512mb of RAM, so as you could imagine it doesnt render the scene particularily well!!
If I had some sort of 'approved' list then I could start checking all of my friends laptops (majority are new-ish so will have 1gb+ of RAM) to see if any of them will work.
Thanks for your help,
Jack
Message Edited by jackllyd on 05-05-2009 05:29 AM
Message 4 of 10
(4,705 Views)
Hi Jack,
Are you able to run any of the 3D picture control examples which ship with LabVIEW on your machine?
When you said that you were able to run a 3D picture control Application on another computer, was it the same application you are trying to run on your machine?
If so, were there any differences between the LabVIEW versions on both machines?
Steve
Message 5 of 10
(4,678 Views)
Hi Steve,
I can run none of the 3D picture control examples on my machine, when I look at the 3D picture control on the front panel is has a white background instead of a black one as I'd normally expect. It appears that the 3D picture control does not work at all on my current machine as it simply crashes LabView.
On the old machine the same application I intially tried worked fine and so do all the shipped LabView examples. I am the same version of LabView on both machines.
Here is all the information Windows gives me when the crash occurs on my machine,
Problem signature:
  Problem Event Name: APPCRASH
  Application Name: LabVIEW.exe
  Application Version: 8.6.0.4001
  Application Timestamp: 4862fd60
  Fault Module Name: ig4dev32.dll
  Fault Module Version: 7.14.10.1329
  Fault Module Timestamp: 46e9b73e
  Exception Code: c0000005
  Exception Offset: 00006e49
  OS Version: 6.0.6001.2.1.0.768.3
  Locale ID: 2057
  Additional Information 1: da97
  Additional Information 2: 7a880e72b9f1636f81b04947e06e5c6a
  Additional Information 3: 976a
  Additional Information 4: 135cff7aab57cb04dcb909e64a768436
Any ideas?
Thanks again,
Jack
Message 6 of 10
(4,660 Views)
FWIW, I ran the USING MESHES.vi example (in NEW EXAMPLES for LABVIEW 8.x - GENERAL folder in EXAMPLE FINDER), and I get a nice black screen.
I re-ran the one I originally had trouble with, and it sort-of works.  At least, it draws a couple of cubes that move.
The cubes disappear and reappear, I don't know what it's supposed to do.
This is after updating from 8.6.1 to 8.6.1f1, you might try updating to 8.6.1, then 8.6.1f1
The 8.6.1f1 patch is here, although it doesn't claim to fix any graphics issues:
http://joule.ni.com/nidu/cds/view/p/lang/en/id/1276
Steve Bird
Culverson.com
LinkedIn
Message 7 of 10
(4,648 Views)
CORRECTION:  The USING MESHES example DOES work on my machine.  The default values draw very dark red dots on a black background, and I was looking at it over VNC, which is probably set to reduce colors.
In any case, I would still suggest updating LabVIEW.
Steve Bird
Culverson.com
LinkedIn
Message 8 of 10
(4,646 Views)
Hi Steve,
That didnt work either, I still get the same problem where whenever I try to do anything with a 3D picture control its crashes LabView. Does anyone have a list of approved graphics cards?
Cheers,
Jack
Message 9 of 10
(4,615 Views)
I would take the issue up with tech support.
Choose the EMAIL option from here:
http://sine.ni.com/apps/utf8/niae_asc.main
Steve Bird
Culverson.com
LinkedIn
Message 10 of 10
(4,613 Views)
