3D Graphs
I have an application where I don't have arrays in x,y,x but a single point scalar which updates continuously. I realise I can fill up a buffer to accomplish
a graph but this intriduces a delay and a refresh. What I want is a single dot that moves around in 3D space. How do I do this?
(3,263 Views)
Simply insert a few "built array" nodes of height one and it will turn your three scalars into three arrays with one elements each, to be fed to the graph. It will draw as a single dot if you set the graph properties correctly.
(3,262 Views)
Well it sort of works except the dor keeps returning to (o,o,o) the origin in between each point it plots.
(3,253 Views)
Please attach a simplified version of your code.
(3,249 Views)
Accepted by topic author tomnz
What appeared to be the problem was that I needed a wait in the loop. For some reason this stopped its antics.
(3,245 Views)
