3D Graph Render Window Programmatically
Hello Guys,
you know it is possible to right click on a 3D picture graph object in run-time and get a new movable window with "Render Window". I would like to be able to open directly that window instead of the front panel picture control.
Actually I have a 2D graph which allows me to see a basic map, I enter a formula for Z(X,Y) and I want to optionnaly show the 3D result. The X,Y plane is more important than the 3D and the XY graph is more efficient, so I don't want the 3D all the time. Actually it works, I just change the Visible property value True/False and it's okay, but the render window is more efficient, the one on the front panel is a bit slow with mouse dragging...
Do you know if there is any property or method to open, close this render window programmatically?
By the way, I would like to know if it is possible to manage "Run-Time Shortcut Menu" for any front panel control, as it is possible with VI Menu bar with event structure. There is a reference constant for the menu bar. I don't find the menu reference for a control.
Thanks for reading,
Jimmy
Message 1 of 1
(3,094 Views)
