3D Graph Merge Module Problem
I am using a 3rd party intaller (InstallShield Express) to produce my
distributables. Into my project i insert the required merge modules, such
as the run-time engine. However when i try to include the ComponentWorks 3D
graph merge module InstallShield cannot merge it into the build. Has anyone
else experienced this or know why this might be happening.
(3,237 Views)
Tom,
If you are using .NET in this project then you may need the updated merge modules, you can get then here:
Unable to Import Merge Module Error When Building Installer in Visual Studio .NET with Measurement Studio 6.0 Merge Modules.
http://digital.ni.com/public.nsf/websearch/36C5E45E15A6862D86256B79005F89BB?OpenDocument
Otherwise this should work just fine, here is the link to it.
Distributing Visual C++ Projects That Contain Tools for Visual C++ Components
http://digital.ni.com/public.nsf/websearch/41694B641CEFF03D862568B900546BCE?OpenDocument
Depending on the error that you get when you insert the merge module you may need to repaor the installation. Depending on the version that you are using you can go to add/remove programs and repair
it, if this is specific to the 3D graph then this could fix it.
Please keep me posted on this problem.
regards,
Juan Carlos
N.I.
(3,237 Views)
Juan,
I tried the solutions you suggested with no improvement.
Using the merge modules found in the first link causes a run-time error
dialogue box:
CW3DGRAPH
Error loading control: A newer version needed. The default settings for the
control will be used.
I have re-installed the merge modules distributed with labVIEW 7.0, and they
still won't compile.
Thanks for your help,
Tom.
(3,237 Views)
