3D CAD Object Animation
What is the best way to animate from LabVIEW a 3D Object (something like a
VRML for example) created with Mechanical CAD.
It's possible in your opinion working directly in VRML file in order to
animate 3D objacts???
Alessio Colzi
(3,035 Views)
Perhaps using an ActiveX container with a program which can display the correct format would be the way to go.
Then you`re basically opening the file in the correct application. Can IE display VRML?
Shane
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,035 Views)
