3645A driver
What is the best way to develop a driver for a Web-Tronics programable supply. Model 3645A. I think it is made in china. It has a serial port for communications. Is there some driver I could try and cut and paste? Not the best way.
Philip
(3,604 Views)
Start at the Instrument Driver Network and at the bottom you will see a section 'Resources for Instrument Driver Users and Developers'. Lots of links on the 'Learn to Build Instrument Drivers' tab.
If you don't need a full driver, you could also use the Instrument I/O Assistant. A driver will be something that is more flexible but you can probably get started using the instrument faster with the assistant. Power supplies are some of the easiest instruments to write code for since they typically have so few functions. You can certainly look at drivers for power supplies from other vendors to get an idea of the general architecture.
(3,600 Views)
Thank you for your advice. I did find some 5.1 Drivers. I have to convert them to 8.2 then to 8.6.1. How do I check the KUDO box for the good advice.Smiley Happy
(3,596 Views)
Click where it says 'Click Here'.Smiley Wink
(3,594 Views)
Where did you find them?  I haven't been able to locate any.
(3,413 Views)
