34970 range and resolution
Im using a 34970A and im wondering if the resolution can be controlled while the range is set to Auto.
The EZ Voltage.vi has a case structure for Range, when the Range is Auto, it doesnt allow the user to choose a resolution and it takes the default resolution(5.5). I tried including a case structure within the case structure for "Auto" range. The instrument gives me Error 103.
It basically does not recognize the values set by the user. I saw one thread which talks abot the same issue, is it possible to switch to a different resolution while the range is Auto???
Thank you,
Eureka
(2,366 Views)
with auto ranging resolution is ignored (although, if you try to override the default "BEEP" -103)  Basically the DAU assumes you just what whatever you'll get .  And, since the resolution is internallly a function of range per the FW, it's impossible to set resolution until the range is fixed.
So, no you can't do that
"Should be" isn't "Is" -Jay
(2,360 Views)
