34401a input term control
Hi, I wanted to measure two AC voltage signals which are connected at the front and back of the instrument. Manually I can change the measurement channel and don't know, if I can program the measurement terminals. Ideally, I measure front input reading and then measure the back input reading.
Is it possible to program this with HP 34401a multimeter?
Thanks for help
(2,724 Views)
IIRC, that is a mechanical switch, not a relay control. That is,
you can not programically change it.
Les Hammer
(2,719 Views)
