32bit float value from analyzer
I am using Labview2014, I have established with some analyzer via Modbus TCP/IP and created some double type variable but how can I get the float value as I can see some raw values now.
Should I use seperate VI's for converting the values?
Attached the modscan value from the analyzer
Regards
Sandy
(3,133 Views)
I have solved this issue by creating  two 16bit integer values of the device and swaped and working but my question is should I create 2 variables for all as I have many data to capture. Is there any alternative methods?
Sandy
(3,052 Views)
Hello, you have posted by mistake in the CVI board: since thus question relates to LabVIEW you should post it in the proper board to have a good support.
(3,027 Views)
Noted
(3,017 Views)
(3,007 Views)
