3 axis choose 2 axis
i have a 3-dimensional array. each dimesnional represent an axis. how can choose either to plot a graoh.
Message 1 of 11
(3,797 Views)
hi guys,
i have a 3 dimensional array. basically, they r in x, y and z array in order. previously, i have used to plot y and z array in an intensity graph. however now, i need x and z array to plot an intensity graph with z being control.
x=64 size
y=256 size
z=255 size
the output is 64 vs 255 graph
please help.
Message 2 of 11
(3,770 Views)
Not entirely sure what you are trying to do, but if you index a 3 dimensional array at any single index, you will get a 2 dimensional array you can plug into an Intensity Chart. Maybe try something like this?
Message 3 of 11
(3,762 Views)
thks steven . but i know about this.
what i need is given 3 d array. each dimensional is classify as x and y and z. and each of them contains a 2D which is capable plotting the intensity. now, we have to plot a graph with x vs z with a control over y.
my
3d array size
x=64
y=257
z=255 for ur own reference.. plss refernce to the earlier post for the code i did.
ty
Message 4 of 11
(3,750 Views)
is the description not clear? pls voice out?
no one is replying
Message 5 of 11
(3,732 Views)
It would help to have some example of your data.
I think you are trying to plot on an intensity graph, these x, y, and z values, but the x and y values are the coordinates for the z value.
Am I close?
- there is always an easy way, but it is always the hardest to find
Message 6 of 11
(3,726 Views)
Hi Sean1985,
After looking though the example you provided as well as the forum posts, I was able to create a possible solution for your application (see attached VI). Just to clarify your issue, to make sure I have the right mindset, you have a 3D array and you want to access the X-Z values (while holding Y constant) to create an intensity graph from. If this is the case, the attached VI creates a subset of the 3D array by holding the Y value constant and then auto-indexing the array into a 1-D array and then back out to a 2-D array skipping the addition of the Y components. It is definitely hard to conceptualize, so free feel to play with the attached file and let me know if you have any questions.
Thanks!
Cheers,
Jonah
Jonah Paul
Marketing Manager, NI Software
Message 7 of 11
(3,708 Views)
thanks
Jonah
I have some enquiry regarding your array subset. by setting y length as 1. How could u fix it as constant? I dun really get it after
reading thru context help  and playing with the vi
Moreover, previously i hoped that i could have some control over the constant. However, i set some other values but it apppeared that output array has no changes.
I hope i could get a 2D graph(X vs Z) at an adjustable constant(y).
thanks
Message 8 of 11
(3,701 Views)
furthermore,
i would like to plot another graph with x vs y axis? how shall this be done?
please reply..
Message 9 of 11
(3,689 Views)
Basically to summarise my earlier posts, i dun quite understand how the vi. Could anyone explain it again? especially the array subset? how could intiialize length is 1 ? whats the meaning?
Next, i wanted to plot another graph using X vs Y only by the same 3 dimensional array?
pls reply...
Message 10 of 11
(3,675 Views)
