2x1D array to one 2D
Hi guys,
I have some problem with connecting two arrays to one. So, i have 2x 1D arrays (both are the same size: 1x63), and what I want to do is create an 2D array (2x63) with variables from smaller arrays.
(1,766 Views)
Hi kacpi,
when you want to build an array then you should use BuildArray…
(1,759 Views)
Yeah, i was trying but, it gave me somthing like this..
(1,743 Views)
Next time attach your VI instead of a picture.
Did you try the basic LabVIEW tutorials?
  • You don't have two arrays, but two scalars as input to built array.
  • You are using an expanded shift register, but are not using its output.
  • There are missing wires.
  • What's the purpose of the FOR loop?
  • How big are the two arrays coming in?
  • Try to learn about autoindexing!
(1,719 Views)
Maybe something like this?
Hint: if you can describe it in one sentence, it should not take a screenful of code!
(1,714 Views)
