2pi constant in formula node
How do you use the 2pi constant inside a formula node? pi(2) and 2*pi do not work. Using labview 6i.
(11,117 Views)
Find attached VI for a version that is working (y=2*pi;). Maybe something else is wrong inside your formula node.
Anyway, you can wire PI as an input for that formula node and use it as a variable.
Hope this helps
(11,117 Views)
Sorry, I forgot to attach the VI.
(11,117 Views)
