2d contour plot with variable x,y spacing
Hi
How do I create a 2d contour plot with the the x-y values spaced at irregular intervals? Intensity plots appear to require equally spaced data.
Any ideas
Willem
(2,996 Views)
Hi Willem,
You are correct in saying that intensity plots require regularly spaced data.
The easiest way to get round this is by padding out your data so that it is regular.
Does your data have a common multiple, if so you can simpley scale it by that factor to make your data regular.
Emma R
NIUK & Ireland
(2,961 Views)
