2d array waveform sampling rate
I am trying to output a 2D array waveform using NI DAQmx. Is there a way to get the 2d array waveform to work with get daqmx.timing.vi?
I am thinking of using the vi to get the sample timing for the daqmx from the waveform.
(2,625 Views)
What do you mean 'work with'? If you want to include timing with your data, use the waveform data type.
(2,618 Views)
