2d array indicator and its refnum
Normally, some kinds of refnum are passed to SubVI.
Sometimes, I want to check the value of the refnum in programming for SubVI.
In case of 2d array, how to indicate the array value from the array refnum?
(3,055 Views)
Wire the refnum to a "value" property node to read out the 2D array value (all elements). (there is nothing special about 2D arrays, the same works for simple numeric, booleans, clusters, etc.).
Of course a 2D array has NxM values, so if you only want a specific element, use "Index array".
(and no, normally we don't pass refnums to subVIs except under very specific needs) 😉
(3,048 Views)
