2d array and excel
How can copy elements from an array to specific column of excel sheet..?? for example if i'm having a numeric array and if i have to put it into 4th column(D1) of exacel sheet,how can i do it..??Any idea..? already i'm copying 2d array into specific sheet of excel,but now i have 3 arrays(numeric,string,string). I want to put 1st numeric in column1,2nd string array in column2 and 3rd string array in column3.
Or please tel how can i put these 3 arrays in a 2d array in 3 different columns. Since 1 is numeric and other 2 are string i'm not able to do that.
Thanks in advance
Sushmith.
Thanking you,
Sushmith
(3,255 Views)
Does the data in your 2-D array have to go into all the same column if so you need to define how you data splits and and convert it to a 1-D array first.  Then you can use the vi from this post to transfer to excel.  Note the data type is variant so it should differenciate between numeric and string.
(3,243 Views)
Sorry - the vi in the link needs work as it expects 2D array of strings.  Need to make it polymorphic to accept numerics too. I will work on this and post later
Ken
(3,237 Views)
Not what I originally intended to do but does this do what you want.  Its a bit 'quick and dirty' but demonstrates the concept.  The repeated parts of the diagram could possibly be turned into as sub VI.
Instructions - Unzip the VIs to a folder and run Untitled.vi.  The other VIs are from my library of 'useful' Excel VIs
You need to have the path constant point to your excel file
Good Luck
Ken
(3,228 Views)
