2D spline interpolation
Hello All
I have only 1D spline interpolation in my LV.
Is there 2D spline interpolation somewhere?
thanks in advance
Pawel
(6,156 Views)
Try the attached VIs. Use them the same way as the 1D counterparts.
(I hope they work correctly. I wrote them long time ago, forgot exactly why
I did it the way I did it...)
-Franz
"pawel" schrieb im Newsbeitrag
news:50650000000800000059970000-1042324653000@exchange.ni.com...
> Hello All
> thanks in advance
> Pawel
[Attachment 2D_spline.llb, see below]
(6,155 Views)
I ran across an NI DevLib Example which shows an example of how to use 1D Spline in two dimensions:
  2D Array Interpolation
  (related download - 2D_interpolation_demo.zip )
In order to better understand what it does, I added many comments to that example, and then extended it.
Their example produces a uniformly-spaced output array, and I wanted to interpolate at an arbitrarily located point.  Also, I figured out how to allow one of the independent variables, [[Xc]], to be specified as a (unevenly sampled / jittery) 2D-matrix instead of as a 1D-vector.  I haven't yet figured out how to generalize the second independent variable [Xr] into a (jittery) matrix too.  I'll probably have to use an approach similar to bilinearDEMO but suggestions would be welcomed!  I have LabVIEW 7.0, so I can't try the new surface-fitting stuff in 8.0.
Note my commented version of NI's "2Dinterpolation.vi" is included as a subVI to the attached demo.  I hope this is helpful.  CHEERS!
(5,876 Views)
(fixed a small bug, and added a few more comments)
(5,864 Views)
Same example extended one more time, now [[Xr]] is also a 2D matrix w/ "jitter".
(This produces identical results as yesterday's simpler "2D_interpolation_demo(modified-DAK_060629(b)).zip" when Xr_jitter is set to zero.)
Note that non-zero jitter on [[Xc]] does not yield noisy "y3" results, but jitter on [[Xr]] does.  (Even compared spline, rational, and polynomial interpolations in this demo.)  Anyone know how to produce better results?
This example code is "public domain", so please share your improvements!  -citizenDAK
Message Edited by citizenDAK on 06-30-2006 11:18 AM
(5,855 Views)
FYI everyone, LabVIEW 8.0 introduced built-in 2D interpolation along with LOADS of other mathematical goodies. It's got 2D bicubic, bicubic spline, bilinear, and nearest interpolation methods. We have Hermite, polynomial, rational, Fourier Interpolation. Did I mention improved Optimization, LevMar and more? The list goes on and on... This is miles beyond our earlier offerings and might be worth a look!
Message Edited by Jarrod S. on 06-30-2006 12:53 PM
Jarrod S.
(5,840 Views)
