2D array to excel
I collected the 2D array information of images from a camera, and write it to spreadsheet. How can I open the spread sheet in Excel? I tried to store, but the Excel just won't open correctly.
Thanks.
TH
(3,018 Views)
If you are using the Write to Spreadsheet, then you should know it does not create an excel file. It creates a text file with a delimiter that you can choose. The default is a tab. Saying the excel just won't open properly is a poor description. What exactly do you mean?
(3,008 Views)
One way is to convert the array of numbers as an array of strings (using Array to Spreadsheet string) and save into a txt file. Define a delimiter and use the same parameters when you read the file under excel.
RKO
(3,000 Views)
That is exactly what the Write to Spreadsheet does. Just look at the block diagram.
(2,997 Views)
