2D array array to alphabetical order
I have huge 2D array where is thousands raws and every raw have 5 columns. Now I want to arrange that whole array to alphabetical order. First columns is arranger, where is string information, other columns are just numerical information.
Tips where i should start?
Thx 🙂
Message 1 of 10
(7,536 Views)
Hi!
how can it be that the first column contains strings and other columns contain numbers?
As far as I know this is not possible in Labview, so I suspect you have a 2D string array...
Anyhow, for sorting a 2D array using the value of the first colum
you can look here:
http://decibel.ni.com/content/docs/DOC-2122
http://zone.ni.com/devzone/cda/epd/p/id/2502
Marco
Message 2 of 10
(7,524 Views)
Hi AliasA,
  Can you  explain a little more clear about your problem?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 3 of 10
(7,521 Views)
srikrishnaNF wrote:
Hi AliasA,
Thanks and regards,
srikrishnaNF
Hi, attached picture tells about what i am trying to do...
Message 4 of 10
(7,506 Views)
Accepted by topic author Alias A
1-Build a cluster with the string as the first element and an array of numbers as the second element.
2-Build an array of clusters from the elements of your tables
3-Sort the array of clusters
Marco
Message Edited by MarcoMauri on 06-07-2010 03:30 AM
Message 5 of 10
(7,497 Views)
Hi AliasA,
in addition to Marco's suggestion (which is suitable!), you shoul dnot forget to convert all the sorting strings to either lower or upper case. In your example you would get "chicken" after "Horse" as lower case letters are sorted behind upper case letters...
In general: array of clusters are sorted by the order of elements in the cluster. When the first element is equal for two clusters the 2nd element is used for sorting and so on...
Message Edited by GerdW on 06-07-2010 11:22 AM
Message 6 of 10
(7,467 Views)
Hello all,
to clarify things said before, I attach a sample VI.
greets, Dave
Message Edited by daveTW on 06-07-2010 11:31 AM
Greets, Dave
Message 7 of 10
(7,451 Views)
@ AliasA: KUDOS are FREE! :smileywink:
Message Edited by MarcoMauri on 06-07-2010 05:19 AM
Message 8 of 10
(7,436 Views)
daveTW wrote:
Hello all,
greets, Dave
Thanks guys... Another solution got from here 🙂
Dave can you please convert example to version 8.6
-Aa-
Message 9 of 10
(7,411 Views)
Message 10 of 10
(7,399 Views)
