2D String array to 2D Numeric array
Many thanks to all involved, who helps me to solve the problem.Smiley Happy
zäpfle
Message 11 of 12
(894 Views)
Hi Rod,
"Does this mean that LV has a problem in converting numbers in locales with a comma as the decimal separator?"
Not exactly. Either LV uses the system settings: than your txt data has to use the comma as decimal separator. Or you have to switch off that behaviour when the txt file uses the point instead.
It's the same on a "English"/"American" pc: when you try to load files with the "wrong" decimal separator you have to catch the error by software...
Message 12 of 12
(892 Views)
