2D Picture indicator scrollbars
When writing a large picture to a smaller 2D Picture indicator, the horizontal and vertical scrollbars automatically move to show the upper left corner of the picture.  Is there a way to avoid this automatic movement?
Chris
(3,808 Views)
The property which defines that position is called the origin.  You can define the "origin" to be something other than (0, 0) dynamically in your program using the origin property in a property node.  The following shipping example actually shows you how to use this property to change the origin:
C:\Program Files\National Instruments\LabVIEW 8.2\examples\picture\pictctl.llb\Picture Control - Zoom Attribute.vi
You can also find it in the Example Finder using Help -> Find Examples... in LabVIEW - click the search tab and search the keyword picture.
Best Regards,
JLS
Best,
JLS
Sixclear
(3,792 Views)
Ah-ha!  That solves the problem.  Thank you for your help.
(3,787 Views)
