-2147220331 Failed to get one or more files while creating the system image.
As I was using the RAD utility to copy an image of a few PXIe chassis I ran into this error:
I wondered if the RAD utility was failing so I used the configuration management palette to try and create a system image. It produced the same -2147220331 error. Of the 4 chassis that I need to copy images from I successfully got images from 2 of them with the RAD Utility and both of the other chassis failed with the same error with both the RAD utility and the configuration palette.
The chassis are:
PXIe-1082 with a PXIe-8880 Controller - Image copied successfully
PXIe-1085 with a PXIe-8880 Controller - Image failed
PXIe-1082 with a PXIe-8880 Controller - Image failed
PXIe-1085 with a PXIe-8880 Controller - Image copied successfully
Any ideas on how to solve this error would be greatly appreciated.
Message 1 of 1
(2,247 Views)
