-2147220296 Error code
I've got the Robotic starter Kit and the error code -2147220296 while trying to install the software in the single board RIO.
I already tried to uninstall the NI-RIO 4.0 software, format the sbRIO disk, restart in safe mode. But the error code still the there.
Does anyone got a clue?
Thank you a lot. This is very anoying!
(2,809 Views)
It works perfectly on my laptop, my 2nd computer.
The connection is reinitialized during the deployment, the error occurs at this moment.
I saw that few peoples have got some issues with virtualizer softwares such as Virtualtool box. I precise that I have one too. Maybe VBox redirect the traffic with its host-network.
Of course, I tried to desactive it, with no result.
If you heard something about that, thank you to help me, my desktop computer is faster for compiling and I dont want to format it!
Thank you.
(2,802 Views)
If you use LabVIEW 2010 SP1, you can try to install the following patch : https://www.ni.com/en/support/downloads/software-products/download.labview.html#306281
Do not forget to reboot after the setup.
If using this patch doesn't correct the issue or if you don't use LabVIEW 2010 SP1, you will need to format or delete the software installed on the sbRIO. (formatting remains the easier way)
You can try to use the NI Robotics Hardware Setup in order to reinstall the software on the Starter kit. If this doesn't work either, you can try to format the robot and reinstall the software by using "Measurement and Automation Explorer" (MAX).
You also can try to take a look to the following forum :
https://forums.ni.com/t5/Real-Time-Measurement-and/Initial-deployment-problem-with-Robotics-Starter-...
Hoping one of those steps will solve your problem.
Jérémy C.
NI France
(2,780 Views)
