2022 Q3 Labview, write data is not working
I need to write data in 4 columns with titles. It was working very well before 2022 Q3 version.
But 2022Q3 has a new function that does not work. It is only written in the first column, not 4 column.
Please have a look at my VI and see how to fix it.
Hong
(1,774 Views)
Hi Zhang Hong,
please revert your VI to a preversion so that others can open it, I am pretty sure most people didn't get LabVIEW 2022 yet. revert to version 2019/2020 would be nice for most users to open it.
To save a preversion copy of the VI, do as following
FrankenChino
(1,730 Views)
@Krapfen wrote:
Hi Zhang Hong,
FrankenChino
It sounds like the OP is having trouble with a function that was added in LV 2022 Q3, so I'm not so sure this will work...
Bill
CLD
(Mid-Level minion.)
(1,708 Views)
I was thinking it might be a Issue not related to the version, just curious about the code. Maybe it indeed related to the version, in that case can not help with my latest version 2020.
(1,697 Views)
I think you might be right.  A little language barrier made it sound like there was something the OP was trying that was new and it didn't work, but I think the OP actually meant that some code that worked before doesn't in LV2022 Q3.
Bill
CLD
(Mid-Level minion.)
(1,686 Views)
Thanks to everyone who replies to me!
I have revised to LV 2020 and all works.
You can see the same function but quite different with 2 versions.
Hopefully, NI will fix the bugger very soon.
Hong
(1,638 Views)
