2015 Unit test framework performance
Are there any performance increases in the 2015 version of the Unit test framework?
Dan Shangraw, P.E.
(3,544 Views)
No. Source wise, as far as I can tell, it is exactly the same as 2013. The performance of my units tests in 2015 appears to be about the same.
(3,516 Views)
As you can see here     http://www.ni.com/white-paper/13503/en/      there have not been any critical updates.
Also, you have to take in count that a Unit Test Framework Toolkit 2015 have systmem requirements like LabVIEW 2015. It is designed to be compatible with the new LabVIEW software.
You can check some information in the following link:
https://www.ni.com/pdf/manuals/375338a.html
(3,488 Views)
