2012 to 2010 conversion bug
I recently found this bug when converting a project from 2012 to 2010.
A foor loop using a conditional tunnel will be converted into a for loop with a case structure with a build array inside fed into a shift register.
The only problem is that this shift register doesn't get initialized, so the just keeps stacking values.
Like this 2012 vi: before2012to2010conv.PNG
and converted to 2010: after2012to2010conv.PNG
You can see there is also an unused constant hovering inside the for loop.
I have tested this in 2013 and the problem does not occure there.
(2,632 Views)
I remember that bug being reported and was claimed to be fixed with 2013 (or was is 2012 SP1?).  Either way, it has been fixed.
(2,628 Views)
Yes, as I mentioned it does not occure in 2013.
I got it using the 2012 f3 32 bit version.
(2,622 Views)
