2012 f2 patch
Hi Robert,
Did this problem start after installing the LabVIEW 2012 f2 patch? After repairing, are the below files present on your system?
C:\Program Files (x86)\National Instruments\Shared\LabVIEW Run-Time\2012\tdtable.tdr
C:\Program Files (x86)\National Instruments\Shared\LabVIEW Run-Time\2012\English\lvapps.rsc
Fred Visser -- SystemLink R&D -- National Instruments
Message 11 of 30
(3,135 Views)
> We have removed the LabVIEW 2012 f2 patch from distribution until this issue is resolved.
Is this issue solved now?
I just installed Labview 2012 (32bit) and the NI-Update-Dienst has now an update for Labview called:
Runtime Software: f2-Patch für Labview 2011 SP1 für 32-Bit-Windows (Runtime-Engine)
Can i install the update?
Thx
Message 12 of 30
(3,074 Views)
Hi OnlyOne,
We intend to resolve the issue with LabVIEW 2012 f2 by releasing an f3 patch in the near future. The f2 update that appears for the LabVIEW 2011 SP1 RTE, should work correctly for most users.
The issue with the LabVIEW 2012 f2 patch is due to a number of factors; primarily, if the Run-Time engine (RTE) is in use while the f1 patch is installed and then in use again when the f2 patch is installed, the installer will delete the aforementioned files. This has been an issue with previous patches as well, but the contributing factor with the f2 patch is that LabVIEW 2012 ships with the 'Variable Web Service" which uses the RTE, and so locks the RTE files even if all other applications have been closed.
That is to say, if you close all applications that use the RTE, and don't have a RTE dependent Web Service running (none ship before LabVIEW 2012), the LabVIEW 2011 SP1 f2 patch is entirely safe to install.
Message 13 of 30
(3,046 Views)
The LabVIEW 2012 f3 patch is now available. Additional details are available in the LabVIEW 2012 f3 Patch Details KB; but in summary, it resolves the aforementioned LabVIEW 2012 f2 installer issues and adds a couple new fixes.
Again, I'd like to apologize for the LabVIEW 2012 f2 installer issue. We've significantly improved a number of testing procedures to help prevent this type of issue from reoccuring in the future.
Fred Visser
National Instruments | LabVIEW R&D | Product Support Engineer
Message 14 of 30
(2,772 Views)
Yes it started after I installed the LabView 2012 f2 patch.  I did not look for the two files.  I already reinstalled LabView 2012 without the patch before I got your reply.
Message 15 of 30
(2,767 Views)
Is there a way for those who have not spent $1k for the VI Analyzer Toolkit to test the upgrade?
Lynn
Message 16 of 30
(2,748 Views)
Lynn
Lynn,
Don't go hog wild but yes!  just put the test attached to the download into LabVIEW Data\VI Analyzer Tests directory
LabVIEW Help file
"The VI Analyzer functionality this topic describes is available only if you
install and activate the LabVIEW VI Analyzer Toolkit or if the LabVIEW Data\VI Analyzer Tests directory contains tests"
"Should be" isn't "Is" -Jay
Message 17 of 30
(2,697 Views)
Fred Visser
Update service works
Link in the KB is the internal site
Access Denied
You don't have permission to access "http://download.ni.com/cgi-bin/errorpage.cgi" on this server.
Reference #18.76e23f17.1350663161.76b1a34
Message 18 of 30
(2,692 Views)
Jeff,
Thanks for the tip.  It works.  Did not find any problems so that is good, too.
Lynn
Message 19 of 30
(2,685 Views)
Does f2 patch need to be installed prior to installing f3 patch?  Or does f3 patch include f2 stuff?
Message 20 of 30
(2,472 Views)
