2009 patch backward compatibility
if i create/modify vi's on a system with the patch installed, will they still be able to be opened on systems that do not have the patch?
(3,122 Views)
They should, but the patch should be installed on the target systems to avoid having things not work the way you expect them.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,119 Views)
