2009 mean.vi
When I try to build an application with the labview Mean.vi I get an error that tells me it can not find the VI.  This appears to be a problem only dealing with the analysis VI's.  I think this is the case because I built my own vi that averages an array and put it in the place of the mean vi and the application works as expected.  Does anyone know what is going on with this?  It is a litle troubling to think that some of the labview math fuctions will be unusable unless yoiu make the VI's yourself to build into an application.
(3,359 Views)
sorry,  a little more clarity would help.  The error occurs when trying to run the application on a machine without labview installed, just the runtime engine.  The application builds as you would expect.
(3,357 Views)
Did you create an installer or did you copy applic.exe file?
(3,351 Views)
I did create an installer
(3,346 Views)
Why did you create another message thread about the same topic?  Please stick with the original thread.
(3,337 Views)
I did not mention that it was a problem with version 2009 in the subject on the original post.  I thought this may have gotten me a quicker response, because my back was against the wall as far as my schedule was concerned.  I was willing to try anything to get a quick response.
(3,265 Views)
