-200428 - Modifying a channel in a predefined DAQmx task
I was pretty sure I had done this before, but maybe not.  I have a predefined task setup in MAX spanning 3 different analog input modules on a cDAQ chasssis.
I'm attempting to modify the thermocouple type on one of the TC channels based on configuration setup data.  So I have the task selected as a constant and feed it into a DAQmx Task node to get the Channel List.  I can see the channel list just fine and all the channels are present there, but when I attempt to break the thermocouple channel out of the array and feed it into a DAQmx Channel node, I get an Error -200428, that the value must refer to a valid task or valid virtual channels.
Any clues?
(3,286 Views)
Accepted by topic author Mike Webster
Hey Mike,
Can you please try it like illustrated in the attached jpg.
Christian
(3,271 Views)
That did it.  Thanks!
(3,266 Views)
You're welcome!
DAQmx programming is sometimes weird.
(3,246 Views)
