2's complement
I was trying to get the 2's complement of a binary number and convert that number to a decimal. But I couldn't get the right 2's complement.
For example, the 2's complement of 10111  is 01001.
How can I achieve that in Labview?
Thanks a lot.
Message 1 of 10
(9,255 Views)
http://digital.ni.com/public.nsf/allkb/57EC3CCB9DA0756786256649006421FF
Jim
Message 2 of 10
(9,250 Views)
Message 3 of 10
(9,246 Views)
not that its difficult......
But knowing what it is and how its defined helps.  Of course, its necessary to understand that an integer's value does not change when you change the radix it is displayed in.Smiley Wink
"Should be" isn't "Is" -Jay
Message 4 of 10
(9,241 Views)
Hi Jim,
I tried that but I could not get the right number.
Like I passed 10111 through the NOT function and it gives me -10112. Then I added 1 and it gives me -10111.
Message 5 of 10
(9,233 Views)
What is the exact data type and display formatting of your 10111 number? Please attach a small VI containing your input. Thanks.
Message 6 of 10
(9,225 Views)
I have attached the vi. Please review it and point out my mistake.
Thanks a lot.
Message 7 of 10
(9,217 Views)
Sorry, here's the VI
Message 8 of 10
(9,212 Views)
I think your code is fine if you get rid of all the string conversions. Instead, use the Radix display (right-click on a numeric control, Visible Items -> Radix). This lets you switch the display of a number from decimal to base 2 (and to hex or octal as well).
If you must do string conversions (again, not needed), use the correct format specifier. %f is for a floating-point value. For an integer, use %d (signed) or %u (unsigned).
Message 9 of 10
(9,202 Views)
Message 10 of 10
(9,201 Views)
