2 parallel state machine
I have actually l watched a lot of videos from NI. Also followed at 5 days course in Denmark. Here we only briefly talked about queues. I try to search for some info, but might return with more questions
Message 11 of 18
(2,760 Views)
Reentrant VIs and subpanels has some special rules which concern the way how you spawn each instance. So there are setups where the subpanel will not work, in others it will.
As Gerd pointed out, my two suggestions are not the only possible way to solve this request.
Queues do work well in such setup as well, so maybe you find that more intuitive than working with subpanels or VI Server.
Norbert
Norbert
Expert: Geometry
Message 12 of 18
(2,752 Views)
@Michael.Koppelgaard wrote:
[...] I try to search for some info, but might return with more questions
That's what this forum is about 😉
I do recommend to create a new discussion thread though if you have questions on specific technologies (e.g. queues) rather than to create a long, single monolithic discussion here....
Norbert
Norbert
Expert: Geometry
Message 13 of 18
(2,748 Views)
You might want to check out my blog. I have been talking about a lot of the issues that you are raising for the past year. Reentrancy, data passing, state machines, all that stuff.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 14 of 18
(2,742 Views)
I would very much like to. Have you got a link to what could be useful for me
(and do you know how to chance the awful green face that is connected to my profile?)
Message 15 of 18
(2,738 Views)
Sorry, I should have said, but the link is in my signature block.
Or HTTP://www.notatamelion.com/
Sorry about the awful green face too... Check in you profile, there should be a way of selecting a new awful face, or entering a link to an awful face that is somewhere online.
Mike...
LabVIEW Champion
Message 16 of 18
(2,729 Views)
Accepted by topic author Michael.Koppelgaard
I really like to use UserEvents to communicate between subVIs and a main VI. Here you will find a nice quick tutorial about Events:
http://www.walkingthewires.com/2015/07/20/something-happened-events-in-labview/
I just put together a small very draft example how to launch two clones of the same subVI, but with different ID values (beside this, you can also feed in different COM ports, device IDs, etc...). I used strings for commands to be quick, but some people prefer Enums for case structures.
Anyway, I hope this example will give you some idea how to do this intercommunication using Events. I attached the mini project as a zip file (LV 2013 version).
Message 17 of 18
(2,700 Views)
THANKS FOR YOUR EFFORD. Just what I need!
I will start looking at your example at once, and might return with questionsSmiley Very Happy
Message 18 of 18
(2,678 Views)
