2 or More objects of a class
Hi:
I have a Battery Simulator class, that has class information (ctl) about a Battery Module (Module Voltage, Current, SOC, Temp, number of Cells etc); What is the best way to create(to simulate) 2 or more Battery Modules; They both contain different data... I need perform Compare operations between them...
Leela.
(2,641 Views)
Why not have 2 class objects of the Battery type..? They won't overwrite each other's data.
(2,634 Views)
There's a major distintion in OOP that you are missing here.  A class is nothing but a blueprint for an object.  It contains no data.  An object is what contains the data.  You can have as many objects of a class as necessary.  And since it is the object that holds the data, you will have no issues with overwritting your data.
(2,608 Views)
