2 or 3 Button Dialog Question
Greetings....
My question has to do with using the 2 button dialog vi/control.  I am currently using it to select either a true or false case (in a case structure) based on which button is selected.  That part is fine.  However I'd like to add to it.  What I'd like to do, is have the dialog pop-up and display as usual, and if no button is pressed after say 5 seconds for example, it would proceed to either the true case or a different case (I'm not sure which, but for right now it needs to pass to the true case if no button is pushed).
I have been looking over the 3 button dialog vi, trying to modify it but have not had any luck.  (And I believe the 2 button dialog vi is unavailable to modify.)
So basically I'd just like it to pop-up and display as normal, and if no buttons are selected within a certain time period, a case is selected automatically and proceeds as normal.
Thanks for any help or suggestions.
Using Labview 7.0 and Windows 2000/XP
Using Labview 7.0 and 2010 SP1 with Windows XP and 7.
(2,781 Views)
Try here.
(2,770 Views)
Thanks for the reply!  The dialog with the time out is what I need.  Somehow I missed that thread when I was doing my searches.
Anyway, thanks again.
(2,749 Views)
