2 front panels, 1 VI, 2 difference monitors???
Dear all,
I am building a VI which includes many control buttons and indicators. What I really want now is to put all control buttons in a front panel and all indicators in the other panel. I want to display 2 front panels on 2 difference monitors. I used Vertical splitter bar, it is ok but one screen is not big enough because I want to show many things at the same time. Is there any way for me to do that?
Thank you for any idea!
(5,001 Views)
Why does it need to be one VI?  It sounds like you want two monitors, maximized on one monitor each.
(4,996 Views)
Thanks for ur reply.
Actually, the indicators here is waveform graph and I have dozen of graph. You are right, I want 2 monitor. One for showing set values, the other for showing measured values. That is why I need 2 separate front panels but only one block diagram.
(4,987 Views)
You cannot have a VI with multiple front panels.  You can give the illusion of this using other techniques like subpanels, and Window Parent Child relationships, but I don't think that is what you want either.
I'm thinking the best way to handle this is with two separate VIs with passing data between them using something like a functional global, queue, user event, or some other method of shareing data to update the UI.
(4,976 Views)
Thank you Hooocahh.
It sounds like there is no way to do that. So upset :). Anyway, I will think about your suggestions. Thank you so much
(4,973 Views)
See this recent thread where the poster was looking to do the same thing.
http://forums.ni.com/t5/LabVIEW/how-to-dual-monitor-application/m-p/3095219/highlight/true#M885496
(4,956 Views)
Thank you very much Ravens!. It would be very helpful 🙂
(4,951 Views)
