2 com port parallely
I am working on a application in which I may need to read value from one com port and need to write the value to other com port and vice versa. During testing I will be doing this lots of time....It might possible that after reading data from one com port and after few proceesing I need to write to other ports and vice versa.
Is using two parallel while loop is good approach?
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 1 of 13
(4,363 Views)
--Ranjeet
Message 2 of 13
(4,351 Views)
Hi Ranjeet,
as an active participant in the forum you should know that it is considered rude to bump threads within 2 hours…
Well yes, I would use separate loops to handle the COM ports.
Message 3 of 13
(4,345 Views)
I know..It was by mistake..My monitor was off
--Ranjeet
Message 4 of 13
(4,342 Views)
I also thought so ,but managing the data will be difficult.. you see I need to read data from one com port and write to other com port.
--Ranjeet
Message 5 of 13
(4,340 Views)
Hi Ranjeet,
you surely heard the words ActionEngine, FGV, queue, notifier, KeyValuePairs, (and several more) before…
Who said it would be easy? 😄
Message 6 of 13
(4,334 Views)
Yes few of them......What is ActionEngine and KeyValuePairs?
Any link will be great !!!!
--Ranjeet
Message 7 of 13
(4,327 Views)
Hi Ranjeet,
do you know how to use Google?
AE
KVP
Message 8 of 13
(4,324 Views)
Yes I know how to use..If you send the link there is no harm.
--Ranjeet
Message 9 of 13
(4,317 Views)
Personally, I would 4 loops here.
1) Read COM1
2) Read COM2
3) Send COM1
4) Send COM2
So you have two loops just for reading the serial ports.  They should use a queue to send the data to whoever needs to process it.  You have another two loops just for sending data that needs to be sent.  They get the data to send via queues.  This is a version of the Producer/Consumer.
Message 10 of 13
(4,308 Views)
