2 Byte-Array nach String konvertieren
In LabView hab ich die Möglichkeit ein Byte-Array nach String zu konvertieren.
Ist das auch mit einem 2 Byte-Array möglich, gibt es da schon eine Lösung?
Oder wie kann ich das 2 Byte-Array in ein Byte-Array umwandeln?
English:
How can I convert a 2 Byte-Array to String
or 2 Byte-Array to 1 Byte-Array?
MfG
Thomas
Message Edited by thomhofm on 05-11-2006 02:07 PM
(4,369 Views)
Hi Tom,
use the "flatten to string"- function from the palette "numeric"->"data manipulation". If you want to make an 8-bit-array, the "split number" and "interleave array"- functions could be fine.
Dave
Message Edited by daveTW on 05-11-2006 02:11 PM
Greets, Dave
(4,358 Views)
Hi Thomas
I have not yet seen a way to convert a U16-Array to String.
Of course you can convert a U16-Array to a U8-Array, but you have to be aware of the fact that you may loose information.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(4,354 Views)
Ok - that's a possibility. I thought about converting ASCII-Codes which are above 0xFF.
Using LV8.0
(4,348 Views)
Thank you!
It works fine.
(4,339 Views)
