2.5 msec delay
Is there a way to delay each iteration of a FOR LOOP by 2.5 msec?  The delay millisecs only allows whole numbers..I think.
Thanks.
(4,042 Views)
Accepted by topic author Clint1000
LabVIEW 2018 introduced a High Resolution Polling Wait VI.  It polls the Windows time to "wait" for whatever time you need.  Do note that it will use 100% CPU when the time left to wait is under 2ms.
If using an older version of LabVIEW, you could make something similar using the High Resolution Relative Seconds.
(4,029 Views)
If you are doing this on a Windows platform you are not guaranteed to get a resolution this accurate. If your timing is this critical yo should be using a real time platform.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,996 Views)
If you have a DAQ you could set up a sample of 4kHz and grab 10 (dummy) samples at a time. That should get you pretty Close. Windows isn't precise in this regard as it's not designed for that.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,990 Views)
Maybe I wasn't think this through.  When you mentioned DAQ a light bulb went off.  What I'm trying to do ( PXI6229) is read 4 channels "simultaneously"..I know..I know I can't w a 6229 but if I read them fast enough its a magnitude better than what I need.  So rather than delay my loop 2.5 msec  I could do what   suggested and manipulate samples and sample rate so that I get my 4 channels sampled ( inside my FOR Loop) at 2.5 msec satisfying my requirement.  Sound legit?
Thanks..
(3,984 Views)
Thanks..
Absolutely !
"Should be" isn't "Is" -Jay
(3,930 Views)
