1d array to hws file help
Trying to make a quick and dirty vi that will take data from a 1D array of doubles read from a csv file and in the end write a .hws file. Using Labview v2012.
Goal - With input of a .csv file, write output to .hws file using Timing Increment (X) and interpolated values (Y).
For loop input (Y values) is a 1D array of numeric doubles and in my case will always be a 1 or zero.  For loop below with DWDT SprdSheet String to Digital was my convoluted attempt to create the type of input that the NI-HWS Express Save requires. Bear with me, I'm a Labview novice.
For loop below appears to index and recieve the proper x and y values inside the loop, but values don't appear to exit for loop.
VI does produce .hws file but appears too small in size to be correct. Can't open .hws to check output cause don't have digital waveform editor (DWE). Person that will receive .hws files from me has DWE.
Not concerned with overall execution speed of this vi. This vi is a means to an end to produce .hws files and will only be used to produce 10 total .hws files for the project.
(2,589 Views)
check these links below related to hws
SignalExpress - Export to Digital HWS file
http://www.ni.com/example/27796/en/
SignalExpress - Import Digital HWS file
http://www.ni.com/example/27794/en/
(2,573 Views)
