1d array to 2d array newbie
I am adding date, time, and 4 values to an array. I want to add these values to a 2d array. When i do it overwrites the previous values. How can i get the 2d array to add the values to the next row. any help is greatly appreciated
Mike
(3,274 Views)
You need to keep the array values in a shift register like in the attached modification.
(3,261 Views)
Thank you very much for your help, works great
(3,258 Views)
Since you always insert your 1D array into an empty 2D array, no wonder that you apprently replace always the same line !
What you have to do is to pass the new array value to a shift register, then back to the insert node at the next execution.
See the attached vi.
CC
Edit : B...y phone. add to much delay !
Message Edited by chilly charly on 05-27-2005 04:49 PM
Chilly Charly    (aka CC)
(3,257 Views)
