1GPIB, 2 or more modules??
Hi! I'm trying to control and acquire data from a HP 6050A Load mainframe
using Labview. It has 4 individual load modules connected thru a mainframe
which has a GPIB. I can run the 4 modules manually, all at the same time.
But when I try running 2 or more modules using my Labview program, it doesn't
work. If I run one module it runs fine. When I start my 2nd module/channel,
the first one which was running normally goes crazy too.It has only one GPIB
though. Can you tell me what changes I need to do in the program to make
all the channels/modules run at the same time and take data out of them
Message 1 of 1
(2,643 Views)
