1D boolean array to individual boolean 0 or 1
Hi, I have a 1D boolean array where i'm getting 5 bits which are input to a 1D boolean indicator (LED's). I need to map the boolean array to individual boolean indicator to glow separate LED's. Any help would be appreciated. The VI and output is attached.
(1,712 Views)
Accepted by topic author AbdullahWasif
Use index array on the boolean array, resized to five outputs. and connect your five booleans to the outputs. LabVIEW 101!
You did not attach any VI, just some pictures. Big difference!
(1,710 Views)
Thanks. It worked.
(1,689 Views)
