1D array not populating
Hi GerdW,
Since the topic is similar, i though I can add my queries here. Sorry about that.
I have an appended array with time string and certain values.
I have initialized a 2D array named Output Array In.
If I run this I get the continuous value only in the first row of the 2D array.
My requirement is I need to get (2011/10/28 10:26:18.155) (00) (09) (22 00 00 00 00 00 00 00) in 1st row
                                              (2011/10/28 10:26:19.155) (00) (09) (22 00 00 00 00 00 00 00) in 2nd row
                                              (2011/10/28 10:26:20.155) (00) (09) (22 00 00 00 00 00 00 00) in 3rd row... and so on in the 2D array.
Working version is LV7.1
KB29
Message 11 of 16
(1,253 Views)
Hi KB,
you need to learn about shift registers or feedback nodes:
Message 12 of 16
(1,248 Views)
I have an another query. Now this while loop comes inside a main vi which runs in a while loop i.e. this is now a while loop inside a while loop. I need the output as:
1) The main loop will run and call the inner while loop.
2) The inner while loop should run once and give the value with the timestamp(10/11/2011 10:00:00; 11 00 00 00 00 00 00 00) and come out automatically (is it possible without pressing the Stop button)
3) The inner loop value should be updated in the indicator which will be present in the outer while loop.
4) Again the outer while loop will call the inner while loop after 1 second.
5) The inner while loop should give the value as 10/11/2011 10:01:00; 11 00 00 00 00 00 00 00)
In case of any change in the value, it should get updated.
Hope I am clear with the query.
KB
Message 13 of 16
(1,235 Views)
No, your description makes no sense at all!
  1. OK
  2. Well, if it should not loop, why do you need an inner loop at all???
  3. You have four indicators in the inner loop and one in the outer loop. Which one should update and with what?
  4. Then place a 1 second wait on the outer loop, right?
  5. Why would the time stamp be one minute later after one second (10:01:00 vs. 10:00:00). That makes no sense at all.
  6. What determines the value in the control name "string"? How ofter does it change?
  7. What is the purpose of the "output array" controls? What determines it's contents?
Message 14 of 16
(1,231 Views)
I had just tried out different methods so I had put it over there. It is justa sample program.
Output array In is the initialized array.
I want the output array to be giving the values as 2011/11/10 10:00:00   00   09   Value
        2011/11/10 10:00:01   00   09   Value
        2011/11/10 10:00:02   00   09   Value
So I just tried with Insert into Array and Build Array via shift registers.
KB
Message 15 of 16
(1,228 Views)
You still make no sense. In what way is Gerds's example above not what you need?
Your problem is are the two stacked loops. Since you initialize the shift regsiter in the inner loop, it will not survive the next iteration of the outer loop, but will get reinitialized over and over.
Message 16 of 16
(1,222 Views)
