192 nos of Waveform Chart on front panel showing Not enough Labview Memory
Hello Everyone
I am using 192 nos of Waveform charts on front panel place over tab control 16 charts on each page total pages are 12 of tab control.
Each Waveform Chart contain  5 Signals.
after placing all charts on front panel it gives error Not Enough Memory to compile.
(3,116 Views)
What does "192 nos" mean?
Are you saying you have a quantity of 192 waveform charts on your front panel?
I'm not surprised you'd run out of memory.  That is a huge number.  Each chart brings a memory footprint with it and it could be rather larger depending on the size of the chart history.
I suggest you rethink your user interface.  Instead of 192 charts, try a using a select number of waveform graphs.  Instead of multiple tab pages containing them, let the graphs float over top.  Store your "chart history" in shift registers.  Whenever someone changes the tab page, change the data shown in the graphs to what is appropriate for that page.
(3,084 Views)
yes 192 no of Waveform chart and each chart contains 5 different plots..in it.
i have kept chart history length 12000
images just shown for only one waveform chart..
(3,070 Views)
Hi AtulS,
memory per chart: 5*DBL*12000=60k*DBL=60k*8B=480kB
192 charts with the same amount of memory: 192*480kB = 92160kB ~ 92MB
From the raw numbers this should be ok, BUT we don't know how many data copies you made in your VI.
And handling 192 charts in a single FP is pure non-sense!
I agree with Christian: rethink your UI design…
(3,055 Views)
My application is i am testing up to 50 Meter long plate taking reading for each mm with the help of encoder pulse
I want to log as well as plot the data points simultaneously..i am using tdms files to log numeric data
But while plotting such huge data points on waveform chart i am facing memory issues..
I am not much experienced for choosing which graph or chart is to used.
Collecting data from 192 channels so i thought using 192 no of waveform chart will help me (bad selection).
Any better suggestion.?
(3,017 Views)
Hi AtulS,
- collect data in one place (like a FGV or DVR)
- decimate data before displaying on a graph (just (one graph!)
(3,005 Views)
